Does your didgeridoo sound fade as you play? Here’s how to stabilize it
Early in 2026, Adhem came to see me for a private lesson. He had a problem: when he played, his didgeridoo sound was beautiful, nicely settled… for one minute, two minutes, sometimes three. And then, little by little, without him understanding why, everything fell apart. The sound lost its clarity and became blurry.
I’m asked this question very often. And no wonder: keeping a stable didgeridoo sound over time is one of the big challenges of this instrument! So let’s look together at what’s going on, and how to fix it.
Two qualities that go hand in hand
For me, there are two great pillars on the didgeridoo. On one side, the quality of your sound, in other words your articulation: that’s what makes your rhythms clear and recognizable. On the other side, the quality of your breath, which makes the quality of your rhythm, because on the didgeridoo, the breath is the rhythm! Smooth circular breathing gives smooth rhythms; beautiful articulation gives a clear speech.
Here, we’re going to talk about clarity. And clarity comes first of all from how you pinch your lips, and more precisely the corners of your lips. If this idea of pressure is still a bit vague for you, I invite you to first read How to get a better, clearer sound on the didgeridoo. Because Adhem’s question was a little different: his sound was good at the start, it was over time that it faded.
First thing to watch: your cheeks
As long as you play with your cheeks deflated, everything is fine. You can pinch the corners of your lips and keep a stable sound. But circular breathing forces us to puff up our cheeks just before breathing in… and that’s often where the pressure quietly slips away. One breath, then another, then another, and without noticing it, the sound has lost its hold.
The trick is simple, but it takes a little attention at first: right after each circular breath, pinch the corners of your lips again, really hard. Really hard! You’ll hear the difference straight away: the sound gets its clarity back instead of sagging. Over time, this little gesture will become a reflex.
Second idea: a reset with an attack
Sometimes, despite everything, your sound slips away after two or three minutes. In that case, here’s a little trick I use very often myself: play a very strong attack. A good, firm “to” or “ko”, or even a KOUF, that very distinctive snare drum sound.
Why does it work? Because such a sharp attack disturbs the position of your lips. It shakes them up a bit… and gives you the chance to put them back in the right place just after, by pinching hard again. It’s a bit like pressing a “reset” button. The KOUF is a bit extreme, but a good, firm “to” or “ko” is often enough to get a clear sound back.
Third idea, less glamorous: saliva
Ah, saliva… Nobody ever talks about it, and yet so many of you ask me about it! When you play the didgeridoo, you salivate, that’s completely normal. The thing is, since we play non-stop, we don’t really get the chance to get rid of it. And this saliva can disturb the vibration of your lips, and so your sound.
I have to confess I don’t have a miracle solution. There are two options. The first is to swallow it while you play: a bit like reverse circular breathing, you keep pushing the air out with your cheeks while you swallow. It takes a little practice, but honestly, it works very well. The second is to let it go into the didgeridoo, especially during the small attacks. Not very glamorous, I’ll grant you that… That’s also why it’s important to clean and wipe your instrument regularly.
And if you’ve found your own technique, share it in the comments, it will surely help other players!
“There is no way to happiness. Happiness is the way.”
Lao Tzu
And above all: play for longer
Beyond all these tricks, there’s one thing that matters more than anything: endurance. Very often, we blow a little, it starts to sound less good, we stop, we censor ourselves… then we start again. But that never builds endurance.
So even if your sound fades after two or three minutes, keep playing. Keep your rhythm going for five minutes, ten minutes, maybe fifteen. You’ll see that when you pick it up again the next day, something will have changed: your sound will last longer, it will be cleaner, more stable. And little by little, that border where the sound starts to weaken will move back, far beyond what you imagined.
If, on the contrary, you struggle to keep going because you run out of air or feel like you’re suffocating, the article Keep playing: why beginners stop on the didgeridoo should shed some light on it.
To conclude
A sound that fades is not inevitable. Pinch again after each breath, dare a sharp attack when the sound gets away from you, tame that famous saliva… and above all, don’t stop too soon. Your sound simply needs time to learn to last.
If you want to build all this into a daily practice, I offer a complete routine in How to progress on the didgeridoo: a 4-step practice routine. And building a clear, powerful sound step by step is what my course The Art of the Didgeridoo is all about.
And you, after how long does your sound start to weaken? Happy blowing!
9994members
0 responses to “Does your didgeridoo sound fade as you play? Here’s how to stabilize it”
